Subject Topic: 1.03.4.1 Observations Post ReplyPost New Topic
Posted: September 21 2004 at 20:03 | IP Logged Quote TonyNo
Up and running! You need to update the ph.gif file in the distribution!
When d'ya think the new docs will be close to done? I can't wait to play with the new active CC!
I still have troubles getting to my Browseamp page in the Web Center; hangs PH cold.
That old "type a value then hit enter" problem on the main PH web page for light dim values is still there (does not change the value).
Posted: September 22 2004 at 10:53 | IP Logged Quote dhoward
You dont need docs...you've been using PowerHome for almost as long as I have . As far as the changes to the Control Center however, all of the functions are documented in the function reference under Control Center.
Im thinking now is the time to try and rewrite the manual. Ive received a lot of suggestions on what people would like to see so I'll probably just start from the ground up (plus I have the new Robohelp program).
We'll work some more on the Browseamp and the problem with hitting enter on the main page. I remember trying Browseamp and not having a problem so I'll definately look at it some more.
How does the rest look? Have you encountered any problems that werent there before? Cant remember if you use Infrared or not, but 1 big issue I need to fix is if you resequence IR code in the IR screen, it goofs up the IR buttons in the Control Center.
Posted: September 22 2004 at 11:19 | IP Logged Quote TonyNo
Heh! I'll check the reference.
No problems so far! I have yet to add IR, but, maybe it's time to...
