onhiatus Senior Member
Posted: October 18 2004 at 17:44 | IP Logged
Anyone had any success integrating line powered heating (baseboard heaters, bathroom heaters, electric radiant floors, etc)
Could be as easy as a relay and an appliance module? None of the currenly available x-10 thermostats seems to support this (plus they're pretty pricey...
Posted: October 25 2004 at 09:37 | IP Logged
Not down here in Florida
Definately an appliance module however. Not sure if what you have uses a plug or not but if you check out smarthome.com you'll find inline appliance modules that might do the trick.
Posted: October 26 2004 at 16:43 | IP Logged
No, they're mostly wired in. Would like to do somthing that is at least arguably to code. I'll look some mroe at smarthome, but again they tend to be pricy... Thanks for the reply.
