        | TonyNo Moderator Group
          While I was at Lowes today, I found some blind-tilting devices mentioned a couple months ago in some other HA forums out there. They are the Cepia Power Ease. They're not very quiet, and not very small, but, they work well and are cheap. They are sold in Master and Add-On packs ($11.98 and $8.98, respectively). The Master includes an IR remote, the Add-On does not.
           | Posted: December 26 2004 at 19:44 | IP Logged |   |
 Note that these only work with blinds that have a tilt wand (not strings), and, the wand needs to be on the left side. Each pack comes with rubber couplers to connect the motor output to three different types of wand stubs (the part the wand normally connects to).
 Installation was easy, and requires no tools. The unit has heavy-duty Velcro attached to the back which mates with an included adhesive strip that you attach to the blind's head rail. Clean the head rail with alcohol, remove the tilt wand from the blinds, select the proper coupler, attach the unit to the wand stub, and press it into place.
 To control them, you can use the remote that comes with the Master pack, learn the codes with your learning remote, or, have PH control them with your IR system (i.e. Red Rat, USB-UIRT).
 One neat feature is that the IR reciever can be left in the unit, or, can be pulled out and located remotely (up to 1' away) for windows that have drapes or a large valance.
 Time for me to add IR to my PH system!
          For those interested, here is a pic of two installed on a double window.
           | Posted: December 27 2004 at 22:58 | IP Logged |   |
        | dhoward Admin Group
           | Posted: December 28 2004 at 16:44 | IP Logged |   |
 Those are pretty cool.  I have a couple of IR controlled battery operated controllers (you can see them here http://www.smarthome.com/3140S.HTML) and they were $50.00!!  Im not too impressed with them either.  The batteries run down too soon (4 AA) and the motor seems too weak.  Im definately heading down to Lowe's to check these out.  Your picture is worth a 1000 words.
 Definately need to add IR control.  You're missing out on at least half of what PowerHome has to offer
  .  Once you start playing with the IR, you'll love it.
 Hope you had a great holiday.
          Wow! $50 each, huh? I can see why you stopped at two! I first picked up three to try, then went back and got five more.
           | Posted: December 28 2004 at 17:01 | IP Logged |   |
 The remote that comes in the Master pack stinks compared to a trained One for All. No problems at all with hitting all three in my living room in one shot. The included remote is more of a sniper rifle to hit one at a time.
 I still need to check the current levels during operation so that I can add jacks to power groups of these from a wall-wart. Currently, 20 AA's and counting...
          I forgot to mention that I ordered my USB-UIRT last night!
           | Posted: December 28 2004 at 20:24 | IP Logged |   |
        | dhoward Admin Group
          Awesome Tony.  You'll really like the USB-UIRT.
           | Posted: December 28 2004 at 23:45 | IP Logged |   |
        | jryan15 Newbie
          i just bought 7 of the cepia blind openers at Lowes on clearance for $1...  Problem is that they did not have any of the master kits.  Does anyone know where I can buy a remote control for them.  Thanks.
           | Posted: January 06 2005 at 06:40 | IP Logged |   |
        | Back to Top |     |
          $1?! Not fair!
           | Posted: January 06 2005 at 07:03 | IP Logged |   |
 Maybe you can order one from Cepia? 800-225-9319
          My USB-UIRT just arrived! I can't wait to get home!
           | Posted: January 11 2005 at 11:54 | IP Logged |   |
 Looking around a bit, I can't find setup info for it (a search of the manual found nothing; also not much here in the forum in terms of setup). Am I just missing it, or, is it just too simple for docs?
        | dhoward Admin Group
           | Posted: January 11 2005 at 13:17 | IP Logged |   |
 It's pretty simple...just be sure to install the drivers for the USB-UIRT (from their website).  After that, just select it within PowerHome, reinitialize, and then go to Help->About->Controllers and you should see it listed.
 Let me know if you need any help,
          Great, thanks!
           | Posted: January 11 2005 at 13:46 | IP Logged |   |
          Wheeeeeee!
           | Posted: January 13 2005 at 21:19 | IP Logged |   |
 Translation: The USB-UIRT is up and running!
        | dhoward Admin Group
          Awesome!!!
           | Posted: January 14 2005 at 09:21 | IP Logged |   |
        | demko Newbie
          Since these posts seem a bit old and I couldn't find anything newer, does anyone know if these are still available at Lowes?  I couldn't find them on their website.  I'm interested in being able to have Power Home automatically open my blinds during the day and close them at night.
           | Posted: February 01 2009 at 23:13 | IP Logged |   |
 Also, Does anyone know if the IR module that comes with windows home media center can be used with PowerHome to transmit or receive IR signals?
 Pat
        | Back to Top |     |
          Those were, unfortunately, only available for a short time.
           | Posted: February 02 2009 at 07:39 | IP Logged |   |
 There are a few companies that make something similar, but the cost is much higher. Somfy and Hunter Douglas come to mind.
        | onhiatus Senior Member
          Re: Using Media Center's IR blaster with powerhome (or any other software). This is supposed to be sorta possible for XP, and some people have claimed to get it working in Vista, but I was never able to get it to work on Vista.
           | Posted: February 02 2009 at 15:09 | IP Logged |   |
 Some possible usefull links:
 LM Remote KeyMap - http://www.lmgestion.net/@en-us/4/22/60/article.asp
 I installed this and it looked like it worked, but could never get it to blast anything and I did not like the way it hijacked the received IR signal.
 The greenbutton - http://www.thegreenbutton.com
 Check around their forums
 Good luck...
 Also if you use Vista Media Center and want to be able to control it from Powerhome look at the VMC TCP/IP Controller Here (or to see my additions - music library access and coming soon an http server - look at the beta release page here.
