Lenny Senior Member
Posted: February 20 2015 at 16:31 | IP Logged
Is there a way to remove an old unused label from
powerhome? If it's in the GUI I must be missing it. I'm
sure it's a record in a table but if I can remove it
through the interface that's preferred.
Also it would be nice to know how to associate things
with a label with SQL. If I export a macro for example
in in SQL make my changes and import it I loose the
labels associated. I'd like to know how to maintain
that.
Posted: February 20 2015 at 22:06 | IP Logged
Lenny,
I need to do some more work to the labeling system.
Currently no way to delete a label from the GUI
(Although you can remove a label from a particular
labeled item).
However, it can all be done through SQL. The labels
are controlled by two tables, labelheader and
labeldetail. To completely remove a label you would
use these two SQL statements:
delete from labeldetail where labelid = 'LABELID'
delete from labelheader where id = 'LABELID'
Adding labels can also be done with the following SQL
statements. To just create a label so its available to
assign use this:
insert into labelheader values ('LABELID','Label
Description')
To assign an existing label to use the following SQL:
insert into labeldetail values
('ITEMID',1003,'LABELID')
The first parm is the ID of what you're assigning a
label to. The second parm is the item type. For
macros, this is 1003. For global vars, this is 1000.
For formulas, this is 1010. Easiest way to determine
the number is to assign a label and then select it to
see the type number assigned. The third parm is the
label ID. To view these tables you can use these
statements:
select * from labelheader
select * from labeldetail
Lenny Senior Member
Posted: February 20 2015 at 22:14 | IP Logged
Thanks for the background Dave and for the prompt reply.
gg102 Senior Member
Posted: February 20 2015 at 23:59 | IP Logged
This brings up something. I like using labels, but here in PH they can be clumsy. Let me show you some psuedo code:
Start_Label:
function(...)
function(...)
goto_label if(something, True_Label, False_Label )
False_Label:
function(...)
end macro
True_Label:
function(...)
function(...)
end macro
In PH, you're required to have a "True_Label" and a "False_label". In most cases, if "false", you would want fall
through to the next step in your macro and only want to take a jump if "True". The issue is that
for every conditional, you need two labels. This makes for a lot of unnecessary "False" labels (just to get to
the next step) when you're pretty much only wanting to take "True" Jumps. Also, you have to make unique "False" labels.
This is bulky.
What might be nice would be to add a new "GoToLabel" jump:
It would be "Go_To_Label_If_True_otherwise_fall_through_to_next".
Using this would eliminate all the unnecessary Labels for unwanted ( fall through) jumps.
ie:
Go_To_Label_If_True if(something, True_Label) (This implies, else next)
Another, simpler, possibility would be to make the "else" label optional, and if missing, default to "Next".
Currently, because of needing two labels, I have been using "Jump" which allows:
Jump if(something, X,1).....Jump x steps, otherwise next.
(BTW, don't know if you know this, but you CAN jump backwards!!!)
Jump if(something, 1,-x).....Jump 1 step, otherwise jump backwards x steps.
(Warning: This can make your brain hurt!)
This makes code changes very difficult because you have to re-count all jumps if you make any changes.
This is very tedious. Using Labels is better.
Posted: February 21 2015 at 00:16 | IP Logged
gg,
You should be already good to go. If you goto a label
that doesnt exist, then it will just fall to the next
line. I use this alot in my code:
10 Goto Label if(something,"LABEL1","")
20
30
40 LABEL LABEL1
In line 10 if the something is false, it goes to an
empty label which will be the next line. Ive also seen
people use something like "nextline" for the false
above and nextline doesnt actually exist as a label.
Lenny Senior Member
Posted: February 21 2015 at 08:29 | IP Logged
The SQL worked as expected however the interface didn't
refresh until I exited restart power home. I ran a
select statement to verify it was gone from the tables
but it still showed up in the interface. I'm assuming
the pick list is read and cached at some point.
Thanks again.
Lenny
Edited by Lenny - February 21 2015 at 08:30
gg102 Senior Member
Posted: February 21 2015 at 09:19 | IP Logged
That helps! It's amazing, you learn something new every day!
Thank you.
Posted: February 21 2015 at 10:48 | IP Logged
Lenny,
You should only need to close and reopen the PowerHome
Explorer. The label data should be refreshed whenever
the Explorer is opened.
I'll run some tests to confirm though. Where are you
seeing the label data still appearing after deleting?
