         Manny Senior Member
           | Posted: May 05 2006 at 21:48 | IP Logged
When I line up a graphic in Control Center design view right under the tab it looks fine in the application. However when I look at the Control Center via the web browser there is noticeably large space between the tabs and the actual CC area. This throws off the measurements in design view that delineate sceen sizes. Is this just happening to me?
           | Posted: May 06 2006 at 11:37 | IP Logged
Do you mean the vertical space between the tabs and the button area? If so, I am seeing that too, so it's not just you. Looks like a line or two.
           | Posted: May 07 2006 at 13:58 | IP Logged
I'll check into this.  I know this is there and I did it for a specific reason.  However, that reason escapes me at the moment  .  I also find this annoying so if I can remove it, I'll get it fixed up.
         Manny Senior Member
           | Posted: May 11 2006 at 17:28 | IP Logged
I think maybe the gap  in CC via web is in case you shrink the browser to the pt where the tabs have to move to a second line?
           | Posted: May 11 2006 at 21:07 | IP Logged
Manny,
 Im almost certain you're right.  I remember putting it there for a reason.  I just need to invest the time and come up with a way so that it isnt necessary (hopefully  ).
