TerryKing Newbie
| Posted: May 28 2006 at 12:21 | IP Logged
I wanted to use x10 to independently control 4 300W Halogen lights on the ceiling of my recently-built barn. I am using gray 3/4" PVC conduit and boxes with wires pulled inside for all wiring in the barn which is unheated thru Vermont winters. I wanted to mount X10 modules right inside each box that the lights mounted on. I looked at using appliance modules, but I would have to make 3 wired connections to the plugs, and find a way to glue or attach the module so that the settings could be changed from outside.
Luckily I found that an X10 SuperSocket module slides nicely right inside the Gray PVC Carlin boxes I am using from Home Depot. Drill two holes, and add a load connection on a plug blade, and you're ready to install. Now I can turn any of the 4 lights on and off from a PalmPad or PowerHome.
How It Worked is shown at http://terryking.us/photos/x10lights/
This could also be used with a blank cover, to make a conduit-inline X10 switch.
Any comments, suggestions, pointers to similar stuff appreciated!
Regards, Terry King ...On The Mediterranean in Carthage
(Back ...In The Woods In Vermont for the Summer)
