MTeator Newbie
Posted: June 15 2006 at 21:21 | IP Logged
Will PowerHome interfere with timers installed directly on the PowerLinc USB via the Smarthome Timer Software?
Posted: June 16 2006 at 15:48 | IP Logged
No. They are independent actions and should not interfere.
MTeator Newbie
Posted: June 16 2006 at 16:14 | IP Logged
Good news, thanks. I'm planning on playing with the 30 day trial this weekend.
MTeator Newbie
Posted: June 19 2006 at 07:52 | IP Logged
Unless I messed up, the timers stopped working after I installed & set up powerhome. However, I went into smarthome's application and told it to reset the timer application, after which they started working again.
Posted: June 19 2006 at 23:38 | IP Logged
Matt,
The initial setup of the PowerLinc with the "Download Core App" and "Clear PLC Database" probably did this. Sorry that I didnt think about this (you should only have to do this one time) and was primarily thinking about just normal daily use.
Glad a simple reset was all that was needed to get you back going again.
Keep me posted in case you run into other problems related to using timers in the PLC and PowerHome. I know not many people are using this and it will help me build up some knowledge base.
