jsferra1 Newbie
| Posted: July 18 2006 at 15:04 | IP Logged
Hello,
I have just built a new box to put PowrHome on and it will running some kind of front end (looking at xlobby) but the issue I have is that PowerHome will not take the registration Key I have. Is there a new type of key I will need since I'm using a new version of PowrHome ???
Jim ....
__________________ Jim .....
mustangcoupe Super User
| Posted: July 18 2006 at 15:23 | IP Logged
Jim,
Your reg key is stored in the PH database file. This is the pwrhome file stored in the powerhome\database directory you need to copy this file to your new box and it will also bring over your config information, and macros ect.... If you are not using the current version of powerhome you may need to use the Database Upgrade Utility
this is in the download section of the webpage.
Quote:
PowerHome Database Upgrade Utility 1.02.2. This package will upgrade your 0.0.5 thru 1.02.1 database to version 1.02.2. You must download and use this package to upgrade your database if you are not currently using PowerHome version 1.02.2 and you wish to upgrade to PowerHome version 1.03.4.
edited to fix my horible typing... :)
Edited by mustangcoupe - July 18 2006 at 15:51
HA newbie
PowerHome - UPB - ELK
| Posted: August 02 2006 at 22:28 | IP Logged
Jim,
If you're having unlock key problems, just email me your registration number. I'll generate you the appropriate unlock key to get you going.
