| TonyNo Moderator Group
          In 1.01.1, moving between windows causes toolbars to disappear and appear. These toolbar positions are something that should also be saved from session to session, along with the window positions.
           | Posted: August 22 2002 at 08:35 | IP Logged |   |
 Tony
        | dhoward Admin Group
           | Posted: August 22 2002 at 09:33 | IP Logged |   |
 No problem, I should of thought of that
  The main toolbar you can set the position from within the Setup screen but nothing currently allows you to save the position for the Explorer toolbar and CC Design toolbar (they are the same so whatever scheme I come up with, the second toolbar, whether the Explorer or Design, will be in the same location.)
