Posted: March 03 2007 at 18:09 | IP Logged
I just noticed this in the code for the page...
Version: 1.03.4.10 </span><span class=ht1r1c1e3><a
href="javascript:window.location.replace('/formula.psp?')"&g t;Refresh</a></span> |
"&g t"
Posted: March 05 2007 at 21:15 | IP Logged
I tried to track this down and all looks ok on the PowerHome side. I noticed from the code above that you're using a PSP page for the formula instead of the built-in ph-cgi/formula command. Based upon this info, it would appear to be something in the PSP page itself. Could you post a copy of what you're using so I can check it out?
Posted: March 05 2007 at 21:26 | IP Logged
D'oh! Never mind!
