Posted: May 07 2003 at 19:24 | IP Logged
I had to think on this one a little while. My guess however is that one of your GV's has a bad character in it which is causing the webpage to not load properly. I'll bet that there is a single or double quote as one of the values. If I remember correctly, this is a problem that Im fixing in the next version but if you could provide me with any details as to what character is messing things up, I can be doubly sure to get it fixed.
Im not at my devel machine at the moment so could give you a better answer tommorrow.
