| smarty Super User
          I was doing some macro clean-up/optimization when I stumbled across this...
           | Posted: November 24 2013 at 09:34 | IP Logged |   |
 The PH command "ph_getinsteonstat()" should return a "0", "1", or "2" per the help documentation.
 It appears to me that in cases were the status is unknown, the "0" is NEVER RETURNED.  In the formula below, I check for all possible states, but I can't make an "Unknown" result - even when I scramble the {Room Device ID} to gibberish.
 if(ph_getinsteonstat("{ROOM DEVICE ID}")=1,"Off",if(ph_getinsteonstat("{ROOM DEVICE ID}")=2,"On","Unknown"))
