         fasttimes Groupie
           | Posted: October 16 2006 at 13:41 | IP Logged
 I can no longer get this function to work at all.  It always evaluates to !
           | Posted: October 16 2006 at 14:05 | IP Logged
Check the changes.txt file. I bet it changed in the last version.
         fasttimes Groupie
           | Posted: October 16 2006 at 20:13 | IP Logged
Yup, it was deleted.
 Dave, can you explain which function replaces this and how the function call works?
  Edited by fasttimes - October 16 2006 at 20:33
           | Posted: October 17 2006 at 16:33 | IP Logged
Fasttimes,
 Yep, the ph_setccobj function replaced the ph_setccbtn function.  Actually, all of the ph_getccbtn??? and ph_setccbtn??? functions have been replaced with equivalent ph_getccobj??? and ph_setccobj??? functions.
 All of the parameters remain the same except for the second parameter which was originally an integer named "sequence" which corresponded to the button sequence number.  This parameter is now a string named "ID" and is the objects' ID instead.  When your database was upgraded, all existing buttons were given default ID's.
 Let me know if you have any problems,
