krommetje Super User
Posted: August 12 2014 at 06:53 | IP Logged
Would it be doable to have an option in PH -> Settings -> Web:
When adding a psp page to Settings -> Web that it can open as a css popup instead of a normal page?
The normal devicescreen stays open and a CSS opens a small PSP-page you just added...?
gg102 Senior Member
Posted: August 12 2014 at 20:32 | IP Logged
Hmmmm,
A popup that says "The garage door has opened." would be interesting.
I guess you'd need to be able to close same popup.....
I'm in!
Posted: August 18 2014 at 19:47 | IP Logged
Peter,
Not quite sure what you're asking for here. Im assuming that you want an option in PH Explorer under PowerHome->Setup->Web under the "Menu" section so you can have a menu URL open in a separate browser window rather than the main window. Is that correct?
Posted: August 19 2014 at 09:44 | IP Logged
Peter,
Yes you are right but not in a separate browser window but in a CSS popup like in this site: http://css-tricks.com/examples/FoldOutPopup/ or like it.
