jostim Groupie
Posted: December 18 2007 at 21:12 | IP Logged
I can't get the command ph_secondsdiffsec to work.
I am trying to make a macro that turns off the lights in the house when nobody is home (or asleep). I have a check on all events that show 'human activity' (lights, IR, motion sensors) and store the time of the latest 'human triggered event'. Every 15 minutes I run a macro that checks if the last human activity is more than 1.5 hours ago. If that is the case, PowerHome turns off most lights.
I would like to use the command ph_secondsdiffsec, because it is smart enough to understand that 00:10:00 is later than 23:55:00. However, I can't get the command to work. I am probably missing something obvious again.
Here is the command I can't get to work:
ph_secondsdiffsec (ph_getglobal_t ("TIME"), now ())
Any suggestions?
- jos
__________________ - jos
Posted: December 19 2007 at 09:07 | IP Logged
Jos,
Use ph_secondsdiff instead of ph_secondsdiffsec. Apparently, the help file is wrong and the text for ph_secondsdiffsec is really meant for ph_secondsdiff.
ph_secondsdiffsec accepts two double values representing seconds and does the same calculation. In this case, adding 86400.0 to the second parameter if it's less than the first parameter.
jostim Groupie
Posted: December 19 2007 at 22:31 | IP Logged
Thanks for your quick answer. Problem solved.
- jos
