Posted: July 04 2008 at 08:10 | IP Logged
How do I use Timed Event Formulas? An example is the 4th of July which is datetime(date(year(today()) + [INCREMENT],7,4),00:00:00). I haven’t figured out how INCREMENT works yet.
nadler Super User
Posted: July 04 2008 at 13:13 | IP Logged
It looks like you replace [INCREMENT] with a value. In the above formula if you replaced [INCREMENT] with a 1 the formula with verify to July 4, 2009. If you replaced it with a 2 then it would get you July 4, 2010. I assume the other timed event formulas work the same way altho I haven't tried them.
Posted: July 04 2008 at 17:23 | IP Logged
That’s real interesting. I wonder what the intent was or better yet how does this work. Halloween also has a [REFTIME] and that’s a puzzle.
jbbtex Senior Member
Posted: July 04 2008 at 22:42 | IP Logged
The Timed Event Formula are used in the Frequency field of a timed event.
You can use them to run macros or whatever on that particular day.
I believe INCREMENT does just that. It increments the year in the July 4 formula so that you can create a timed event that fires each July 4.
You can create Timed Event Formula for birthdays too.
__________________ Brady
Posted: July 05 2008 at 10:32 | IP Logged
So, if I got this right, when I set the Frequency field to July 4th and give it a Raw Formula the formula will execute the next July 4th. I gather INCREMENT is an internal thing.
Posted: July 05 2008 at 12:37 | IP Logged
That's correct. But be sure to adjust the reference time. The default is 00:00:00.
Posted: July 05 2008 at 12:54 | IP Logged
Thanks for the help Brandy… I won’t need to build one for my birthday as yesterday was it and the rest of the nation.
Posted: July 05 2008 at 14:48 | IP Logged
Happy Birthday!
Posted: July 05 2008 at 14:52 | IP Logged
Must have gotten into the sauce yesterday and was thinking Brandy Brady. One year older and still can’t type. Thks again…
