Subject Topic: Number conversion Post ReplyPost New Topic
Posted: January 10 2009 at 10:39 | IP Logged Quote GadgetGuy
Is there any way to use hex values in ph function data
elements?
When setting colors for Control Center objects it sure
would be nice to enter "FF0000" instead of "268369920"
for the color RED. The latter is not exactly user
friendly!
nadler
Posted: January 10 2009 at 11:48 | IP Logged Quote nadler
You can use
rgb(255, 255, 0 )
instead.
The above is red or yellow I forget which.
Posted: January 10 2009 at 11:49 | IP Logged Quote TonyNo
I use the rgb() function, but I think there is a way to use hex. I can't find it now.
rgb( 200, 0, 0 )
Posted: January 10 2009 at 15:07 | IP Logged Quote GadgetGuy
Roger That!
Thanks. I see it now in the function list.
Much friendlier!!
Posted: January 10 2009 at 18:15 | IP Logged Quote TonyNo
Ah ha!
ph_hextonum( "FF0000" )
Searching Help for "hex" did not find that.
Edited by TonyNo - January 10 2009 at 18:16
Posted: January 10 2009 at 19:34 | IP Logged Quote GadgetGuy
Good for you!
Sometimes I just browse the Function Index list in the
Help window to see if I can see anything that I might
want to learn more about, or use later.
I've started my own notebook of useful functions doco so
I can find them later!
This one will get added.
