device Newbie
Posted: May 26 2009 at 21:11 | IP Logged
I was wondering if there is documentation anywhere for message type above 6 return in TEMP4 on an insteon device change.
Thanks in adavance,
D
Posted: May 27 2009 at 11:58 | IP Logged
The only one I could find besides the 6 listed is 8 which is the result of a status scan. It suggests there is a 7 somewhere, maybe, but I did not find mention of it.
device Newbie
Posted: May 27 2009 at 17:45 | IP Logged
I am seeing 7, 8 and 9 and just wondered if there was documentation anywhere. I can surmise based on the event log but it is nice to be sure and make sure the "case" statement is complete.
D
Posted: May 27 2009 at 17:59 | IP Logged
If you have an Event Log showing the 7,8, and 9 cases, how about posting the Insteon event that precedes each case. The forum is a major reference source for PH and any contribution you can make would be appreciated by all.
device Newbie
Posted: May 27 2009 at 19:11 | IP Logged
You mentioned type 8
This created a type 7
Incoming Insteon received on Insteon DM controller PLMCTLR1. From Address:[10.8E.C9] To Address:[0F.44.94] Flags:[39] Cmd1:[17] Cmd2:[255]. Decode: Direct ACK. From: CRAFT CLOSET To: PLMCTLR1, On
This created a type 9
Incoming Insteon received on Insteon DM controller PLMCTLR1. From Address:[10.87.40] To Address:[0F.44.94] Flags:[102] Cmd1:[17] Cmd2:[5]. Decode: ACK of Group Cleanup. From: GARAGE DOOR MAIN To: PLMCTLR1 Group: 5, On
Cheers,
D
Posted: May 28 2009 at 11:18 | IP Logged
D,
Here are all the types for the Insteon Change trigger
1 - Direct command from the PLC/PLM (PowerHome's controller)
2 - Group cleanup from the PLC/PLM (PH's ctlr)
3 - Group broadcast from the PLC/PLM (PH's ctlr)
4 - Direct command from a device other than PH's ctlr
5 - Group broadcast from a device other than PH's ctlr
6 - Group cleanup from a device other than PH's ctlr
7 - Direct ACK from a device other than PH's ctlr
8 - The change occurred in response to a status request from the PH ctlr
9 - ACK of Group cleanup from a device other than PH's ctlr
Another way to state it (I believe this is the way of documented it before) follows:
1 - Outgoing Direct command
2 - Outgoing Group cleanup
3 - Outgoing Group broadcast
4 - Incoming Direct command
5 - Incoming Group broadcast
6 - Incoming Group cleanup
7 - Incoming Direct ACK
8 - Change due to Status request from PLC/PLM
9 - Incoming Group Cleanup ACK
device Newbie
Posted: May 28 2009 at 14:32 | IP Logged
Thanks - this allows me to be sure I have all the cases covered.
D
