Subject Topic: ph_sql bug? Post ReplyPost New Topic
kev21986
Posted: December 17 2009 at 16:05 | IP Logged Quote kev21986
I can run this SQL Query from the script editor in PH if I set
it to SQL and get results.
select * from macroheader;
But if I run this query in the Direct SQL page I get -1
results. Also if I run this formula in the script editor I don't
get results.
ph_sql(2,"select * from macroheader;")
Am I doing something wrong?
Kevin Smith
@respectTheCode
Back to Top View kev21986's Profile Search for other posts by kev21986 Visit kev21986's Homepage
kev21986
Posted: December 17 2009 at 16:37 | IP Logged Quote kev21986
Found the problem. The semi colon at the end of the sql
statement needs to be removed. This works.
ph_sql(0,"SELECT ID FROM macroheader")
Kevin Smith
@respectTheCode
