Subject Topic: Smarthome 2466S status Post ReplyPost New Topic
aisaev
Posted: June 02 2010 at 15:08 | IP Logged Quote aisaev
Hello again,
I'm trying to get the status out of 2466S, to see whether
lights are on or off using
ph_insteonwithret("GLIGHTS",XX,YY). The problem is that I
could not find any documentation for the values of XX and
YY. Device Status window knows how to read it - it shows
it, so I assume you guys know what those values should be.
Back to Top View aisaev's Profile Search for other posts by aisaev
Posted: June 02 2010 at 16:02 | IP Logged Quote grif091
The cmd1 value (XX) is 25 (0x19), the cmd2 value (YY) is 00. The returned value will be between 0 (device off) to 255 (device full bright).
sjvonstein
Posted: June 03 2010 at 15:11 | IP Logged Quote sjvonstein
ph_getinsteonlevel("GLIGHTS") should return a value representing its state. 0 for off, 255 for on
Correct grif?
Back to Top View sjvonstein's Profile Search for other posts by sjvonstein
Posted: June 03 2010 at 16:35 | IP Logged Quote grif091
The ph_getinsteonlevel() returns the value that is in the PowerHome database. The device is not physically accessed by this function. The ph_insteonwithret() function issues the specified Insteon command and returns what the device returns to Powerhome in response to the command. The first is what Powerhome thinks the device status is based on command activity. The second is the actual device status at the time the command is issued. The two values can be different.
