Subject Topic: Intro tp Powerhome Javascript/VB Script Post ReplyPost New Topic
hotcoffee76
Posted: August 29 2010 at 22:05 | IP Logged Quote hotcoffee76
Hi,
Is there a primer or introduction to using javascript or vb script to control Powerhome? Reading the guides and help I can find has left it unclear how to get started with this.
Back to Top View hotcoffee76's Profile Search for other posts by hotcoffee76
Posted: August 30 2010 at 11:50 | IP Logged Quote grif091
The following line in a Macro (Formula) will invoke the VB Script file below that. The VB Script file is a junk file I use to test things so do not look at it for any meaningful function.
ph_runscript_0(0, "c:\temp\avbscript1.vbs", "testfunction")
@language="vbscript"
Sub sub1()
     ph.usermessage("user message from vb script")
End Sub
Function testfunction()
     const ion = 17
     const ion10 = 10
     const ion7 = 7
     const ioff9 = 9
     ioff = 10
     stringPH = "text of message with VBS variable inline " & ioff & " remainder of message"
     ph.usermessage("test message from function " & ion + ioff9 & " more message")
     ph.usermessage("second message from function")
     ' rv=ph.insteon("ICON SWITCH TEST", int(ioff) + ioff9, 254)
     ph.usermessage(stringPH)
End Function
