Subject Topic: Logical Operations Post ReplyPost New Topic
Posted: November 12 2010 at 09:17 | IP Logged Quote GadgetGuy
I'm feeling very stupid about this, but can not find anything in the PH doco, nor in my extensive notes about how to NEGATE an expression.
That is if I want to make a decision if the temp is NOT greater than 35 degrees, there does not seem to be a "NOT" operator in PH such that I can say . . .
if(NOT{TEMP}>35,0,1)
To keep the formula more understandable in use I don't want to use {TEMP}<=35
For the benefit of others looking for similar information let me state that PH does have an AND and an OR logical operator such that one can say . . .
if({TEMP}>35 AND {WIND}<15,1,0)
which would produce a "1" when the temp was greater than 35 AND the wind was less than 15.
Thus I am surprised that there seems to be no NOT operator.
Posted: November 12 2010 at 10:15 | IP Logged Quote TonyNo
I can't find anything either. I'm guessing that I have been conditioned to work around this one. ;)
Posted: November 12 2010 at 11:03 | IP Logged Quote GadgetGuy
David!
In the grand scheme of things, I can't believe you left this out, so it must be hidden somewhere!
Can you enlighten us?
Posted: November 12 2010 at 11:03 | IP Logged Quote dhoward
Heh, super simple...the not operator...is not .
1 = 1 when evaluated will equal true. To negate it, use:
not 1 = 1
This will now equal false. Of course, you may need to use parenthesis to clarify what is actually being negated.
Edit....in your example above:
this will almost work. It wont work because of how globals are substituted. If you change it to:
if(NOT {TEMP}>35,0,1)
add a space after not, it works.
Edited by dhoward - November 12 2010 at 11:23
Posted: November 12 2010 at 16:08 | IP Logged Quote GadgetGuy
Dave - THANKS!
I could not believe there was not a NOT! When I tried to use it I got a 'syntax error' so assumed that NOT was not valid. (Wow. Is that not a crazy sentence, or what?!)
It was as simple as the space needed. Geeze. It always seems to be that way. The fixes are so simple once one knows.
BTW - In the event new doco is produced at some time in the future, consider putting in a discussion about AND/OR/NOT and put them into the Help system too, as they are not present there now.
Posted: November 13 2010 at 07:50 | IP Logged Quote GadgetGuy
Dave - a thought for product improvement. I have run into this "Syntax Error" issue on many occasions and it has often fooled me into thinking I had a formula problem when in fact I did not.
The problem is that when one executes the Formula Check in the Formula Builder window, if one of the formula variables is a [LOCAL] or [TEMP], etc then it is undefined and when the formula is evaluated a Syntax Error result is produced.
In point of fact the formula does not have a Syntax Error, only the evaluated results do.
Is it possible to catch this and give a more accurate error comment such as "Undefined Variable" ?
This would really help debugging efforts.
Edited by GadgetGuy - November 13 2010 at 07:52
