Posted: June 17 2004 at 21:38 | IP Logged
I knew I should've waited to eat dinner .
Tony's got you covered. While PowerHome cant specifically "ping", it does include functions to retrieve a URL. If the URL retrieval comes back blank or times out, you can assume the router needs rebooting, which PowerHome can do using a Powerlinc.
Another minor point. PowerHome only currently supports the RS-232 version of the PowerLinc and not the USB version. I am working on adding this support as we speak, but this controller is being a bear so Im not there yet.
Also, as Tony pointed out...PowerHome would be overkill if this is all you were doing. PowerHome is a rather large GUI driven application and while I don't like to think of it as "memory intensive", its not lite either.
