phil13 Groupie
Posted: April 19 2005 at 14:35 | IP Logged
Hi dave,
i've a little problem to make working a little vbscript.
Can you tell me where is the problem ?
i launch the script with the powerhome script editor with 2 parameters "off", 1
The first time i execute the script after to have reinitialized powerhome, i've an unexpected error on line 11 (the first ph.X10).
Then after, each time i execute it, i've an unexpected error on line 5 (not the same line ...).
sub cmd_filtration (cmde, manuel)
dim tempo_dem, tempo_auj, tempo_hchp, retour
tempo_dem=ph.getglobal_s ( "TEMPO DEMAIN" )
tempo_auj=ph.getglobal_s ( "TEMPO AUJOURDHUI" )
tempo_hchp=ph.getglobal_s ( "TEMPO HCHP" )
if cmde="off" then
retour=ph.setglobal_n ("TIMER FILTRATION" , 0)
retour=ph.x10btn ( "H", 1, 2, 0 )
end if
if cmde="on" then
retour=ph.setglobal_n ("TIMER FILTRATION" ,60)
retour=ph.x10btn ( "H", 1, 3, 0 )
end if
end sub
tempo_dem, tempo_auj, tempo_hchp are not still used.
Philippe
Posted: April 19 2005 at 15:47 | IP Logged
Philippe,
It's my problem . Apparently when I changed the definition of the ph_x10btn function to take an integer as the level, I failed to update the ph.x10btn script function and it was trying to feed a string to an integer field.
Anyways...you can download a fixed phscr.pbd file from here: http://www.power-home.com/download/phscr.zip.
Shutdown PowerHome and then unzip the above file and overwrite the one in your PowerHome directory. Restart PowerHome and the ph.x10btn function should work as expected.
Let me know if you have any other problems,
Edited by dhoward
phil13 Groupie
Posted: April 20 2005 at 09:30 | IP Logged
OK for ph_x10btn with the patch.
Otherwise, i've another similar problem :
it's seems that code doesn't works :
dim duree
duree=40
retour=ph.setglobal_n ("TIMER FILTRATION" , duree)
The value in "TIMER FILTRATION" is false.
But this code works :
retour=ph.setglobal_n ("TIMER FILTRATION" , 40)
In fact, i need to put a calculate value in a global variable.
How do i have to proceed ?
Philippe
Posted: April 20 2005 at 13:34 | IP Logged
Phillipe,
I tested this and got errors as well. I didnt get "false" but some equally bizarre number. Ive combed the code several times as well inquiries on the net and the best Ive been able to determine is that when the variable is passed from vbscript to PowerBuilder, it's not able to properly reference the actual variable value. When a numeric literal is passed (the 40 in your working code), it doesn't have a problem. But it's unable to interpret a numeric variable (string variables seem to work fine).
Anyways...the workaround is simple enough. We just need to make the variable look like a literal value and then it'll work fine.
Change your line:
retour = ph.setglobal_n("TIMER FILTRATION",duree)
To:
retour = ph.setglobal_n("TIMER FILTRATION",cint(duree))
The "cint" function effectively removes the variable reference. You can also use "cdbl" and then be able to pass integers as well as doubles.
Not many people use the scripting capabilities of PowerHome so I appreciate your efforts in testing.
Let me know how it goes and if you have any other problems.
