phil13 Groupie
Posted: May 25 2005 at 03:24 | IP Logged
Hi,
is there a way from a command line or an other application to send datas to powerhome ?
Something like that : EXEC "powerhome.exe %DATA1"
And how can i get it in powerhome ?
philippe
Posted: May 25 2005 at 08:07 | IP Logged
There are a few ways to get data into PH...
In my latest exersize, I used a batch file to ping some local machines and redirected the output to a text file. I then read the text file into PH and pull out info from it.
If your app supports Windows Messaging, PH can send and receive data using this.
The PHCommand util in the download section could also be used, depending.
Anyone else have other ideas?
phil13 Groupie
Posted: May 25 2005 at 09:28 | IP Logged
tony,
i've though about text file but what's append if powerhome want to read it and the other application want to write in it in the same time ?
Does windows manage this problem ?
Otherwise, the Phcommand utility seems to be a very good and powerfull idea. I've tried but i've a problem.
The utility documentation say need to have PBVM80.DLl, LIBJCC.DLL and PH32.DLL installed but on my computer i can't find pbvm80.dll but i've a pbvm90.dll ...
Does someone heve pbvm80.dll ?
Posted: May 25 2005 at 12:54 | IP Logged
Don't they come with phcommand? I have them in my phcommand folder. Maybe I copied them there from somewhere else?
I would send it to you, but I don't know if there are licensing issues. Dave should be able to assist here.
phil13 Groupie
Posted: May 25 2005 at 13:25 | IP Logged
it don't come with phcommand.zip.
After a little search it seems that :
- pbvm90.dll is for PowerBuilder 9.0
- pbvm80.dll is for PowerBuilder 8.0
Posted: June 01 2005 at 11:47 | IP Logged
Phil,
The phcommand.zip in the download section is a little outdated. I would post the pbvm80.dll (and other PowerBuilder 8.0 runtime files) except that I don't have it loaded on my new development machine (old notebook crashed).
I will rework this utility to use the latest runtimes and post them when I have it done.
Posted: June 10 2005 at 18:02 | IP Logged
Check out the PowerHome Download page. At the bottom Ive added two new utilities for command line control.
The first is command line control using the PowerHome Windows Messaging interface. This program will allow you to execute a formula from the command line of the local PowerHome machine. Includes complete VB source code.
The second is a command line control utilizing the PowerHome Socket Server interface. Using the program will allow you to control PowerHome from the command line of the local machine AS WELL as any remote networked machine. Requires the socket server interface be enabled within PowerHome. Again, with complete VB source code.
One of these utilities should do the trick for you.
Posted: June 10 2005 at 19:06 | IP Logged
Cool! Are these different from phcommand?
Posted: June 10 2005 at 19:17 | IP Logged
I just d/l'ed phsscmd_setup.exe and got this error...
Error 1324.The path ***IS_STRING_NOT_DEFINED***
contains an invalid character.
krommetje Super User
Posted: June 12 2005 at 10:59 | IP Logged
I've got the same problem here!
Posted: June 12 2005 at 22:21 | IP Logged
It was a bad build from InstallShield. I just rebuilt the install and uploaded it. Give it a try and let me know if this one is ok or not.
Yep, a little different from the old PHCommand. The PHCommand was written in PowerBuilder necessitating the PowerBuilder runtimes. I believe it also used the webserver as the interface. Both of the new files are written in VB with source code (for learning purposes) and use the newer Windows Message and Socket Server interfaces.
Good luck,
phil13 Groupie
Posted: June 13 2005 at 09:52 | IP Logged
Thanks dave.
phil13 Groupie
Posted: June 13 2005 at 11:35 | IP Logged
i've tried to load VB projects and i had somes problems i think because i'm using Visual basic express 2005 beta 2.
http://lab.msdn.microsoft.com/express/vbasic/default.aspx
When i make the automatic update from vb6 to vb 2005 :
- i can't open phsscmd because problems of winsock licence
- i can open phwmcmd but i've upgrade issue in code :
(sorry for french but my vb is in french ...)
Friend Class PHWMCmd
'UPGRADE_ISSUE: La déclaration d'un paramètre 'As Any' n'est pas prise en charge. Cliquez ici : 'ms-help://MS.VSExpressCC.v80/dv_commoner/local/redirect.htm ?keyword="FAE78A8D-8978-4FD4-8208-5B7324A8F795"'
'UPGRADE_WARNING: Impossible de résoudre la propriété par défaut de l'objet cds. Cliquez ici : 'ms-help://MS.VSExpressCC.v80/dv_commoner/local/redirect.htm ?keyword="6A50421D-15FE-4896-8A1B-2EC21E9037B2"'
iRet = SendMessage(hPwrHome, 74, 0, cds)
End Class
Posted: July 05 2005 at 11:20 | IP Logged
Philippe,
Im not familiar with VB 2005 Express so not sure what upgrade issues you may have. However, the code is very simple so I'll just copy and paste it below.
The code for phwmcmd is:
Private Declare Function FindWindow Lib "user32" Alias "FindWindowA" (ByVal lpClassName As String, ByVal lpWindowName As String) As Long
Private Declare Function SendMessage Lib "user32" Alias "SendMessageA" (ByVal hWnd As Long, ByVal wMsg As Long, ByVal wParam As Long, ByRef lParam As Any) As Long
Private Type COPYDATASTRUCT
dwData As Long
cbData As Long
lpData As String
End Type
Dim hPwrHome As Long
Dim cds As COPYDATASTRUCT
Private Sub Form_Load()
Dim sData As String
Dim iRet As Long
sData = Command()
hPwrHome = FindWindow(vbNullString, " PowerHome ")
If hPwrHome = 0 Then
MsgBox ("PowerHome is not running")
End If
cds.dwData = 0
cds.cbData = Len(sData)
cds.lpData = sData
End
End Sub
The code for phsscmd is:
Private Declare Function GetPrivateProfileString Lib "kernel32.dll" Alias "GetPrivateProfileStringA" (ByVal lpApplicationName As String, ByVal lpKeyName As String, ByVal lpDefault As String, ByVal lpReturnedString As String, ByVal nSize As Integer, ByVal lpFileName As String) As Integer
Dim sReturnData As String
Dim bConnect As Boolean
Sub form_load()
Dim sRemoteHost As String
Dim sRemotePort As String
Dim sUserID As String
Dim sPassword As String
Dim sEncode As String
Dim sAuthorize As String
Dim sContentLength As String
Dim sFormula As String
Dim tStart As Date
Dim tEnd As Date
sFormula = Command()
sRemoteHost = Space(256)
sRemotePort = Space(256)
sUserID = Space(256)
sPassword = Space(256)
sRemoteHost = Left(sRemoteHost, GetPrivateProfileString("settings", "remotehost", "127.0.0.1", sRemoteHost, Len(sRemoteHost), ".\phsscmd.ini"))
sRemotePort = Left(sRemotePort, GetPrivateProfileString("settings", "remoteport", "8500", sRemotePort, Len(sRemotePort), ".\phsscmd.ini"))
sUserID = Left(sUserID, GetPrivateProfileString("settings", "userid", "yourname", sUserID, Len(sUserID), ".\phsscmd.ini"))
sPassword = Left(sPassword, GetPrivateProfileString("settings", "password", "yourpassword", sPassword, Len(sPassword), ".\phsscmd.ini"))
Winsock1.RemoteHost = sRemoteHost
Winsock1.RemotePort = CLng(sRemotePort)
bConnect = False
Winsock1.Connect
tStart = Now
Do
tEnd = Now
DoEvents
Loop While bConnect = False And DateDiff("s", tStart, tEnd) < 10
If bConnect = False Then
Winsock1.Close
End
End If
sAuthorize = "Authorization: Basic " + base64encode(sUserID + ":" + sPassword)
sContentLength = "Content-Length: " + CStr(Len(sFormula))
sReturnData = ""
Winsock1.SendData ("FORMULA" + vbCrLf + sAuthorize + vbCrLf + sContentLength + vbCrLf + vbCrLf + sFormula)
tStart = Now
Do
tEnd = Now
DoEvents
Loop While bConnect = True And DateDiff("s", tStart, tEnd) < 20
If bConnect = True Then
Winsock1.Close
End
End If
Winsock1.Close
End
End Sub
Sub winsock1_DataArrival(ByVal bytestotal As Long)
Dim sTemp As String
Winsock1.GetData (sTemp)
sReturnData = sReturnData + sTemp
End Sub
Sub winsock1_Connect()
bConnect = True
End Sub
Sub winsock1_Close()
bConnect = False
End Sub
Function base64encode(sData As String)
Const base64 = "ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz0123456 789+/"
Dim lBlock As Long
Dim iCount As Integer
Dim iLen As Integer
Dim sTail As String
iLen = Len(sData)
iCount = 1
Do While iCount <= iLen
lBlock = Asc(Mid(sData, iCount, 1)) * 65536
iCount = iCount + 1
If iCount <= iLen Then
lBlock = lBlock + Asc(Mid(sData, iCount, 1)) * 256
iCount = iCount + 1
iCount = iCount + 1
sTail = ""
Else
sTail = "="
End If
Else
sTail = "=="
End If
sEncode = sEncode + Mid(base64, (lBlock And &HFC0000) / 262144 + 1, 1)
sEncode = sEncode + Mid(base64, (lBlock And &H3F000) / 4096 + 1, 1)
If sTail <> "==" Then
sEncode = sEncode + Mid(base64, (lBlock And &HFC0) / 64 + 1, 1)
If sTail <> "=" Then sEncode = sEncode + Mid(base64, (lBlock And &H3F) + 1, 1)
End If
sEncode = sEncode + sTail
Loop
base64encode = sEncode
End Function
As far as the Winsock Control licensing issue....Im not sure if this control is included with VB Express so that may be the issue. You can however see the events that Ive coded for the Winsock Control and you may be able to create the project from scratch if importing is a problem.
