Subject Topic: Idea on a PH Thermostat Post ReplyPost New Topic
krommetje
Posted: June 11 2006 at 11:00 | IP Logged Quote krommetje
Hey Guys?
any Ideas on how to perfect this?
insert into macroheader values ('TEST','TEST',0,0,1);
insert into macrodetail values ('TEST',1,27,'',NULL,'if({SENSOR1} > 2500,"OK","NEXT")',0,'');
insert into macrodetail values ('TEST',2,26,'',NULL,'OK',0,'');
insert into macrodetail values ('TEST',3,36,'',NULL,'"Temperature Measures {S1}"',0,'');
insert into macrodetail values ('TEST',4,36,'',NULL,'"Shutting down Thermostat"',0,'');
insert into macrodetail values ('TEST',5,12,'K',6,'',0,'X10-1');
insert into macrodetail values ('TEST',6,12,'K',103,'',0,'X10-1');
insert into macrodetail values ('TEST',7,39,'',NULL,'',0,'');
insert into macrodetail values ('TEST',8,26,'',NULL,'NEXT',0,'');
insert into macrodetail values ('TEST',9,36,'',NULL,'"Temperature Measures {S1}"',0,'');
insert into macrodetail values ('TEST',10,12,'K',6,'',0,'X10-1');
insert into macrodetail values ('TEST',11,12,'K',102,'',0,'X10-1');
insert into macrodetail values ('TEST',12,36,'',NULL,'"Switching ON thermostat"',0,'');
insert into macrodetail values ('TEST',13,39,'',NULL,'',0,'');
the Idea is to have PH to have control over the Central heating Thermostat... PH would have the function of controler so that the Thermostat stays in its normal programming... So the Temperature in the living room can't get any higher then 25 degrees celcius with the Central Heating in the example code. What I am looking for is e.g. a time-checking...a low-value checking or something else...
do you have any ideas?
Posted: June 11 2006 at 22:58 | IP Logged Quote dhoward
Peter,
I imported the macro and checked it out. It seems like it would do what you want. All you would really need to do is call it from a timed event that ran probably every 5 minutes.
krommetje
Posted: June 12 2006 at 15:53 | IP Logged Quote krommetje
Dave I am going to put this on hold until i've got this incoming cueue problem solved...
krommetje
Posted: July 29 2006 at 03:18 | IP Logged Quote krommetje
Any Ideas on checking time/date/season etc? Would be nice to have more interaction...
