PowerHome Macros, Scripts, and Formulas Repository
 PowerHome Messageboard : PowerHome Macros, Scripts, and Formulas Repository
Subject Topic: MACRO: Testing between 2 Times Post ReplyPost New Topic
nadler
Posted: December 21 2006 at 11:05 | IP Logged Quote nadler
This simple macro is called by other macros. It checks to see if the time is between 6 am and 8 am. If so it says "Good morning" and runs the Get Weather macro which announces the complete weather.
insert into macroheader values ('TESTING BETWEEN TIMES','TEST',0,1,1);
insert into macrodetail values ('TESTING BETWEEN TIMES',1,37,'',NULL,'Called from other macros, this macro tests between 2 different hours',0,'');
insert into macrodetail values ('TESTING BETWEEN TIMES',2,16,'',NULL,'If(hour(now())>5,1,999)
',0,'');
insert into macrodetail values ('TESTING BETWEEN TIMES',3,16,'',NULL,'if (hour(now())<9,1,999)',0,'');
insert into macrodetail values ('TESTING BETWEEN TIMES',4,9,'',NULL,'"Good Morning"',0,'');
insert into macrodetail values ('TESTING BETWEEN TIMES',5,1,'GET WEATHER',1,'',0,'');
',0,'');
