Posted: June 02 2009 at 20:14 | IP Logged
All,
Spou, one of our forum regulars, has put together an Excellent how-to for assembling a 1-wire network and interfacing it with PowerHome. This 23 page PDF document is very detailed and Im happy to host it here on the PowerHome site.
I wasnt sure where was the best place to put this file so everyone could easily access but this made the most logical sense. Anyways, the how-to can be found here: 1-wire Network to PowerHome
Edited by dhoward - June 02 2009 at 20:14
woody Newbie
Posted: December 07 2011 at 17:15 | IP Logged
Hi
Ive read Spou's tutorial and got to the point of capturing the temperature readings into a file but I cant see how to get the data into powerhome using the global variables?
Also is there a better way of doing this via a plugin and if so how?
Hope someone can help as its frustrating the hell out of me!
Thanks Woody
judetf Senior Member
Posted: December 08 2011 at 15:55 | IP Logged
I'm not the best person to answer this, but I made it work. Basically you need to create a macro to read the file that is storing the data, and then parse the data in the file, and stored the parsed data in a Global Variable.
Here are some of the key commands in my macro. I have 4 different sensors, and so the four ph_regexdiff statements capture the temperature for each location. I'm a hack, so I can't explain why it works, I just know that after futzing around I made it work:
woody Newbie
Posted: December 08 2011 at 17:13 | IP Logged
Hi
thanks for the reply, although Ive realised I wasnt supposed to post in this area :-(
After sitting down fresh, Ive found how to create the global variables and the macros but im getting an error calling the script. I notice that you are not calling a script but reading a file instead. That looks simpler so Ill give it a go.
Thanks again.
Woody
woody Newbie
Posted: December 09 2011 at 12:55 | IP Logged
Hi
Ive managed to read the file OK but how do you get the global variable names into the centre column. Mine just shows EMAILNAME and two other labels as in the image below:
thanks
Posted: December 09 2011 at 16:29 | IP Logged
In the left pane just above Macros is the Global Variables selection. Click on that and add whatever Global Variable names needed. They will then show in the pulldown.
woody Newbie
Posted: December 10 2011 at 09:26 | IP Logged
Im sooo stupid! I just hadnt scrooled down!
thanks for the help, Ill work out the regexdiff function now.
Woody
