PowerHome and Elk
 PowerHome Messageboard : PowerHome and Elk
Subject Topic: PH and new ELK install Question Post ReplyPost New Topic
nadler
Posted: October 21 2008 at 09:19 | IP Logged Quote nadler
By old alarm panel was hit by lightening and I'm
replacing it with an ELK M1G. I'll be using the wiring
from the old panel (hopefully).
Of course I want to integrate ELK with PH and have seen
2 ways to do it. Smarthome sells the Elk with the M1-
SXP which uses a PLC (I have an extra PLC) and I've seen
posters use the ELK-M1XEP ethernet connection. I think
I would like to use the ethernet connection because the
Elk panel is close to my router and I wouldn't have to
deal with a PLC and my existing PLM, but I don't know
the disadvantages of going this route. Are there any
disadvantages? Will setup and communication between ELK
and PH be similar?
Anything else I should know?
Noel
